So i've heard the term "double roller timing chain" thrown around plenty of times on this board. i'd really like to know what it is and why it seems to be a poplular mod. who can help me out?
Re: double roller timing chain
Well it's really not a mod by itself. Only need the double roller chain if you are changing your valve springs to a higher seat pressure (130#+ or the ls6 90#) along with an aftermarket camCheck out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
alrighty... what exactly is it tho? i know what a timing chain is (duh) but whats w/ the double roller part?2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Its just a chain that is 'thicker' meaning it looks like two chains in one.
See this pic
The reason you add the double roller chain is to eliminate the chain tensioner on the stock single chain. The dampener is just plastic and will wear out quicker with the higher springs pressure.Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
i have 1.9 roller rockers with ls6 springs and ls1 retainers and im not useing a double roller though did replace my timing chain with a Rollmaster timing chain cuse my stock one was old and did not want to risk anything happen with my set up2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
