hows this sound? - FirebirdV6.com/CamaroV6.com Message Board
hows this sound?
  • hows this sound?
    ok so at first i was like woot i want to go full turbo in the camaro im trying to buy. then i started thinking about it and i think the wife would really notice that over a deeper exhaust note. so here is my new idea.
    camaro l36
    zzp stage 2 heads, gt1 cam, stage 2 tb, gtp roller rockers, port match intake manifold to heads, pacesetter headers, 180 drilled t-stat, e-waterpump, gtp injectors and a pcm with tuner. bolted to a 5spd with a 3.42 limited slip rear.
    also thought about tossing the n2o kit zzp has on it for some straitline runs. most driving will be daily/autocross.
    Re: hows this sound?
    you could just buy an ls1 and it would probably be faster stock than your car with all the mods
    and a stock t-5 maxes out at like 300hp i think, so you might be cutting it close with a nos
      QUOTE=flyboy367]ok so at first i was like woot i want to go full turbo in the camaro im trying to buy. then i started thinking about it and i think the wife would really notice that over a deeper exhaust note. so here is my new idea.
      camaro l36
      also thought about tossing the n2o kit zzp has on it for some straitline runs. most driving will be daily/autocross.[/QUOTE]
      Is It worth the money?? IMO
      heads ----- NO
      Cam ----- Maybe
      Tb ----- no
      rocker arms - yes
      Port job -- no Hp gains are too small for the money and PITA
      Headers --- YES
      Water pump-- NO, I dont think they are made for a 3800
      t-stat 180 -- No (go with hyperstat 160)
      Injectors --- NO Gtp injectors are 36# I would go no more than 24# (stock=22#
      Tuner ------ only if it is hptuners
      rearend ---- YES
      N2O ------- Yes but use N express
      Btw It is poss. to get 200+ rwhp for less than $2000 in mods.
        yea, i dont want an ls1. i worked on them a good amount of time and the 3800 as well. i kust like the 3800 engine. my gtp was cutting low 12's at 4100lbs. sure thats supercharged but maybe ill go turbo. still on the fence
          heads ----- yes
          Cam ----- yes
          Tb ----- no, zzp TB is for FWD cars
          rocker arms - full roller, not GTP specific
          Port job -- yes
          Headers --- yes
          Water pump-- yes, they make them for the 3800
          t-stat 180 -- yes, drilled
          Injectors --- depends what year you have
          rearend ---- YES
          N2O ------- ?
            You know, other people make stuff for us other than ZZP, lol.
            Get yourself a good head/cam package from lance at abbott racing along with 4.10 gears, a little suspension, and boltons with a decent tire and you will see 13s all day long with tuning and practice.
            Instead of doing rockers and a cam, just get a cam ground with more lift and skip the cost of rockers all together.
            Shawn<br />2002 Silver W68 Firebird
              ^ do you get commission?
                what are you talking about? I only recommended 2 products from a specific company...the company that has the record for quickest n/a 3.8 V6 fbody and the company whose cam got me the best cam-only result of any 3.8 V6 fbody.
                So to me, that seems like a good company to go with :)
                Boltons, tire, gear, and suspension can be had from anywhere.
                :rolls eyes:
                My point was that ZZP focuses on the GPs, not fbodies.
                I also dont understand why you put that injectors are only necessary for certain years. He is going to need injectors.
                  I was just making a joke, anyway.
                  I think the quickest n/a v6 f-body is harry doolittle as in another thread.
                  Nobody really goes for a cam only record. It's like having intake only, exhaust only, elec. water pump only, rockers only, tune only, etc. Too many.
                  He just showed interest in ZZP which is a good company. They hold the FWD 3800 record. And v6 f-bodies seem to have the 3800 as well.
                  I was going to give some recommendations if he had 00-02 with multecs.
                    Harry doolittles car is a full-built stock eliminator race car...not a regular car that any joe could have running.
                    And most people do have a cam-only record, it just isnt big in the V6 fbody world...but on LS1tech it's a big deal who can get "x" times with stock heads.
