What's a hybrid? - FirebirdV6.com/CamaroV6.com Message Board
What's a hybrid?
  • #31
    Re: What's a hybrid?
    Very nice, good luck with it
    • #32
      Thanks!
      Worked on my engine finally for a little bit today instead of everyone else's, lol. Got another 3500 comming in tomorrow, and will be dissasembling/cleaning all day.
      Got the cam bearings out...
      And honed the cylinders...
      Now I got to order the rings (hopefully tonight after the kids are in bed), and maybe this week the crank, cam bearings and oil pump will go in.
      • #33
        Looks like it's gonna come together well .. good luck with it!!!
        • #34
          Got the cam bearings in after a slight snag yesterday, also the crank, rods and pistons are done...
          • #35
            Lookin good, it'll be done before you know it
            • #36
              Is this a 3.4 with a 3500 top end swap? I'm not sure what I'm looking at here.
              Originally posted by LETZRIDE
              I've never touched a rear end before
              • #37
                Yes.
                Post #3:
                Originally posted by Forced_Firebird
                3rd gen. The block is a 3.1 now, and only being used as a mock-up while I rebuild the 3.4 to go in. The top end is from a 2004 malibu 3500. The valve springs are getting traded for a set from an LS6, and 1.7 roller tip rockers in place of the stock 3500 1.6 roller fulcrum rockers. I will be using a 75mm Nothstar TB, custom forward facing headers and turbocharging it.
                Here are some more pics if you like...
                http://s158.photobucket.com/albums/t...ybrid%20Build/
                I don't update here as much, but the rockers are staying 1.6 roller fulcrums due to LIM clearance problems.
                • #38
                  lol. ok thanks. It was a lot to read so I kinda just skimmed over it really fast.
                  • #39
                    awsum! im gessing you have the hood with the cool ram air slits and thats how your manageing to fit the 3500 upper intake under the hood right?
                    • #40
                      Look at the first pic on post #1. It's a 1990 firebird (3rd gen) and the 3500 top end fits just fine under the hood. In fact it is a bit lower than the 3.1 top end that came stock. The MPFI intake manifolds are a lot taller than the 3.4 manis.
                      • #41
                        Ooo, didn't realize it was a 3rd gen. I was wandering why it had a 3.1
                        • #42
                          so whats the advantage to doing a hybird rather than droping in a 3500?
                          • #43
                            Ease.
                            The 3500 block has different motor mount on the pass side (rear in the FWD vehicle), starter is on the opposite side, where the Gen1 60* has the oil filter (3x00 filter location will hit the motor mount), and the oil pan is just a big square and will hit the k-member.
                            When I can get the time/money to install a tubular k-member, there will be a an entire Gen3 60* motor in my car. I'm thinking at least a 3500 twin turbo, unless I can find a good deal on a 3.6DOHC or a 3900.
                            • #44
                              I see what your saying. I relly want to do this too.
                              • #45
                                Is there a big power difference between useing the 3400 top end and the 3500 top end?
