fuel pump - FirebirdV6.com/CamaroV6.com Message Board
fuel pump
  • fuel pump
    how hard is it to put a inline fuel pump in and by pass the intank one
    Re: fuel pump
    You can't bypass the in tank pump unless you go with some custom fuel cell setup.
    An inline pump is to help draw fuel from the tank. The best bet is to drop the tank and install a walbro 255 in tank pump.
    What is your reason for needing more fuel at this point?
      Re: fuel pump
      oh its in my trans am. the fuel pump is going out and i dont want to drop 1000 bucks in labor and another 700 on another fuel pump.
        Re: fuel pump
        I just replaced my fuel pump on my 94 LT1 trans am...
        It's very easy...
        $125 for a walbro 255lph on summitracing (cheapest new pump i could find and it's good quality and high performance if you ever decide to mod)
        Install took about 30 min using the "trap door method"
        1999 Camaro Z/28
        1973 Firebird Formula
          Re: fuel pump
          hey man do you have any pictures of your trap door so i can see were i would have to cut?
            Re: fuel pump
            Check back on here in a few hours and I'll go take some pics...
            1999 Camaro Z/28
              Re: fuel pump
              thanks man
                Re: fuel pump
                You can eliminate the in tank pump, but it will take some fabrication and welding, probably not something you want to attempt for the first time.
                  Re: fuel pump
                  yo wigger, just do that on your back by dropping the tank. call me. i'll walk you threw it like i said !!
                  WAWA-A-HOLIC
                    Re: fuel pump
                    wigger.... :O ok my little tomato i will buck up and do it the right way :)
                      Re: fuel pump
                      i knew that you would love wigger, since your treadding that fine line to get there. next thing you know your going to get close to my abs and get wigger in an old english tatto across the abs lol
                      WAWA-A-HOLIC
                        Re: fuel pump
                        oh fo sho. get some nice bling. 22s on my camaro. huge system. maybe a airbag system so i can three wheel it. ... lol.........and i will have those abs soon enough.. with
                        inspired by Kristen tattoo right under them
                          Re: fuel pump
                          you think they make an asian print tattoo that says that?
                            Re: fuel pump
                            i dont think... i know.. i already have it :)
                              Re: fuel pump
                              you asian print is the one that "b!tch" on your *** right?
                              WAWA-A-HOLIC
