What all is involved with porting/polishing your intake? Has anyone on here done this themselves and if so what was the outcome? Could this simply be done using a dremmel tool? Or should I spend the 200 bucks and send the upper and lower off to Abbott? Damn thats alot of questions......?
Porting intake manifold
Re: Porting intake manifold
well if it were me i would just send it off.. it involves quite a bit actually abbott is going to get places you can't get with a dremel just my 2 cents and without heads the intake won't give you much gain at all.2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
Port matching is the biggest gain to be had IMO.
It is easy to do, and more challenging to do well.
Buy a set of gaskets, put them on the manifold and trace the opening with a sharpie.
Do the same on the lower intake, then smoothly grind down the colored areas.
Leave the heads to professionals.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
And I see where you are coming from 99BlackW68, but the only way to gain experience is to just do it...and being the realist I am, chances are im going to screw it up. But if I do destroy the intakes, they are relatively inexpensive to get from a wrecker yard. I'll post some pics before I put them on to see what you guys think.Last edited by conbirdable; 08-30-2007, 01:55 PM.
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...4 weeks ago
