Hey guys I finaly got my AR stage 3 heads from UDLOSE. I wanted to clean them up some. I was wondering if dousing them with brake or parts cleaner would be ok if I cleaned it off good with some water. I was also thinking of rubbing a piece of light grit sand paper over gasket areas to clean those areas. If this isnt a good procedure for cleaning the heads let me know and also tell me how to do this so I dont mess something up. If anyone is wondering the heads only have 3k miles on them from his car and they look to be in great shape. Thanx guys!
Cleaning AR heads
Cleaning AR heads
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Tags: None
Re: Cleaning AR heads
be VERY careful with water it will rust the **** out of them if you do not 100% dry everythinng i would get some carb cleaner it evaps pretty quick and it will clean anything esp. the "valucraft" brand i think its autozones house brand2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
Yea, I was tired when I wrote the post so didnt think about the rust it could cause. Ill prob just use the cleaner and the sand paper on the gasket areas.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
I just used break cleaner and a scotch pad on mine. Maybe hit it with a gasket scraper if it has any gasket residue on it. When you going to be installing them? I just finished installing my AR stage 3 heads and AR n/a cam and AR P&P intakes. If you got any questions I can help you out.Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
I hope to install them within the next 2 months. I just now got my car back from the new paint job and we are painting the mirroros and ground effects today. How was the gain from the setup. Ill have a similar setup only I have the comp GT cam.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
2 months??? At the latest Chris, you should have them done by next weekend. Lol, anyways, painting the GFX? What did you end up getting to replace the front lip?~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
Im gettin a set of stock W68 forn lips.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
