A Cam Question - FirebirdV6.com/CamaroV6.com Message Board
A Cam Question
  • A Cam Question
    Well I have a question that i couldn't find answers too.
    1: I'm getting a CompCam's Cam. I was wondering if All this stuff is also needed as well To run my Cam? Or can i get rid of some things for now and then just keep upgrading it slowly.
    Mind you this is going into a 1996 Camaro 3.8L with the Angled TB. Also the car has 91k Miles on it as well.
    CompCams Push rod Set - 7.050" Overall Length
    CompCams Titanium Valve Spring Retainer Set
    CompCams Valve Springs
    CompCams Pro Magnum Rocker Arms - 3/8 Stud, 1.75 Ratio
    CompCams High Energy Hydraulic Roller Lifters
    And here is a pic of the Comp Cam i am getting. I appreciate any and ALL info! So Please let me know! Thanks!
    Re: A Cam Question
    wrong section.
    moving...
    Follow me!
    Or this
      Re: A Cam Question
      get new intake gaskets as well
        Re: A Cam Question
        What are the specs on the cam itself? No one can answer those questions without that info.
        I'm guessing right now the 1.75 rockers will be TOO much lift with an aftermarket cam.
          Re: A Cam Question
          that cam looks like the grind lance had...... that cam really aggressive cam you need p/p intakes and p/p heads.
          you will be good on the lifts with the 1.75 rockers if you use 130# springs. (BTW the only place to get comp rockers is from ZZP, no other cars rockers fit our car) and they only have 1.7 and 1.73 ratio.
          then you will have to tune it out the *** to be able to drive the car.
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            Re: A Cam Question
            That cam is huge as hell.
            It will idle poorly.
            With the 1.75 ratio rockers your lift will require ported heads to flow well at the higher lift. The duration is really large.
            Since you have a limited knowledge of cams, I would say that you should NOT put this cam in your car.
            1997 Dodge Viper GTS
              Re: A Cam Question
              I appreciate all the help guys. Looks like im just gonna go with a NA Cam since im going to be running Nitrous. Also going to go with Abbot's Kit. Anybody have any reviews for Abbot's Cam Kit?
                Re: A Cam Question
                although abbott is a good company, I wouldn't buy a Cam kit or anything that's supposed to have everything you'll need...it's a bit more secure to buy the stuff you need piecemeal
                  Re: A Cam Question
                  Abbott will treat you right..... hell my head cranked and he said send it back and he would take care of it.... no questions asked :banana: :banana:
