what would be the best for my car. I have heard good things about the ER rockers but im still not sure if i should get the 1.9 roller rockers or the ER rockers
1.9 roller rockers? or ER ratio rockers?
Re: 1.9 roller rockers? or ER ratio rockers?
either the aluminum 1.9 roller rockers
http://www.zzperformance.com/grand_p...=510&catid=104
or these
http://www.zzperformance.com/grand_p...=555&catid=104
if you read up on zzp's testing they say the ER rockers produce more horsepower than 1.9's. But that was compared to modified stockers. These modified rockers, like the ER, have the seats re-welded. I have heard of a couple cases where people had failures from bad welds (but not specifically zzp). The aluminum one's are full roller and lightweight and would definately have better results than the modified 1.9's and maybe the ER?. The ER are cheaper but the aluminum rockers come with pushrods. I don't think you could go wrong either way.
Originally posted by NachiusIf you don't ever plan on getting a cam go with the 1.9 aluminum rollers.
Lighter meaning they rev faster, and higher lift win win.Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: Powerdyned '02 Pewter Camaro
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
im going to go with the full rollers, if im going to spend the money, may as well get the best.
What 1.9 roller rockers are the best to get? the aluminum rockers from zzp or the ones from intense racing?
i did it on mine :)
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
i also used ls1 retainers and ls6 springs2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
cool i bought the #105 springs, and ill be getting 1.9 full rollers as soon as i can decide on what brand to get.
what rockers are those that you have?
got my from intense racing2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
yeah i was think of taking out the ls6 springs and putting in #105 springs2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
