rod question - FirebirdV6.com/CamaroV6.com Message Board
rod question
  • rod question
    so i have a 3.4 as you guys know and i got a cam 212/212 and i was wonderin if i needed to get different size pushrods?
    Re: rod question
    I don't think that i had to get different ones. I know that I got new comp ones but same size though. I will look around tonight for the box and part number.
      Re: rod question
      awesome
        Re: rod question
        new cams dont require new pushrods.
          Re: rod question
          sweet that helps alot and another question my buddy said when your doing springs you have to raise the piston to the right height in order to install them right and he said that was on an Ls1 and i was reading some where else you can take them all off at the same time and not worry about it so my question is what is the right way to install springs on a 3.4?
            Re: rod question
            Just watch to not drop the valve...then you'll be taking the heads off...
              Re: rod question
              Unless you decked you block, are installing roller rockers, or are messing around with different height head gaskets, use stock length pushrods. Jegs or summit sell an air valve hold adapter for your air compressor. It allows you to fill the cylinder with air while you remove the valve springs. They are around 10 bucks. Also some folks stuff a nylon rope into the cylinder to keep the valve in place.
              69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
