seems there is an issue running a heads cam and header package on a electronic throttle body. it sits at 15% at idle. no way to change it and it runs full lean at idle but has enough fuel to power a funny car. 43.5 lb injectors running basically a stock tune without the turbo yet and it still reads full lean at idle. let me know if anyone has experience with etb or a way to bypass anything. they are supposed to be 0.3% at idle.
Re: electronic throttle body
Originally posted by Smoke PantherI'm running an electric throttle body on my cammed car with headers, and my HP Tuners logs show no problems at idle, even when I had stock injectors in
I think the problem is you're running a stock tune
with H/C and bigger injectors.
yea we have a ses light but all it displays is electronic throttle code. and by almost stock i mean egr delete trans pressure boosted fans on time and such and pulled some fuel. other than that nothing. maybe a little advanced timing also.
