Has anyone ever installed a 4.3 V6 into a Camaro? My car is a 95 with a 3.4.
4.3 in Camaro
Re: 4.3 in Camaro
Don't waste your time. Use a set of 3500 heads and LIM, and a 2000+ 3100/3400 UIM and you will see some nice gains. I'm expecting over 250hp with a cam, porting & polishing of the entire intake, headers, MegaSquirt for tuning, LS6 springs and a 7200 RPM redline. If you are going to go through the trouble of swapping a V8, why not have a V8? The tranny bell housing uses the small corporate pattern, so you would need motor mounts, 90* tranny, and at least a way to program your ECM for the changes (or swap the appropriate ECM for the engine).
