well i have connected everything and eliminated exhaust leaks and my wideband is measuring lean at idle when the cam is loping. if i put it at 2000 rpm it runs between 13.9-15.7 afr it jumps alot and i can't figure out why. held at a steady rpm it shouldn't have any problems with the afr.
aem uego reading lean
Re: aem uego reading lean
You need to have the engine loaded to correctly calculate A/F. Revving in neutral isn't doing anything for you.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
both. i was measuring at idle to try to get an idea how much fuel was going in to it. this being a completely custom set up if i have lean at idle i sure as hell will have worse under load. we tested everthing now it runs real rich so we are throwing a new tune in it to see if we can't get it back around 12:1 or so. i know idle reading doesn't mean **** or revving it. but i also don't like holes in my pistons and i don't think my engine does either :0)
