Has anyone ever put a 4.3 in a camaro?
4.3 in Camaro
Re: 4.3 in Camaro
Probably, but why? The 4.3 jimmy/blazer engine is rated at less hp than the 3.8. Unless you're talking about a Sy/Ty engine, it's not worth it. I think you'd have fitment problems with the way the Sy/Ty turbo is mounted.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: 4.3 in Camaro
V8 is a much better idea. Or 3500 top end swap for the 3.4. Do a search if you are interested in that.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: 4.3 in Camaro
Lots of them. You're going to have to find a really small air cleaner, and cut the plastic cowl behind the hood. There are tons of swaps and writeups on ls1tech.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: 4.3 in Camaro
I was on ls1 performace a couple times with some posts. Guy seam kinda of snooty.They were all negative about it. They all say just get rid of it and buy a z-28. But I dont have the money for that . I can get a complete 350 for a 100.00 bucks from my buddy. I will check out ls1tech . Thanks for your imput
Re: 4.3 in Camaro
FWIW, you're going to need different engine mounts, and transmission to make this swap work. Also, headers are going to be rough.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
