I have tried to search but did not find anything relevant.
I have bought a cam kit. Comp cams grind nr: CSV-6 260H-10
212 degrees at .050 in/ex
Dont have the numbers in front of me right now, but should be
.440 lift in/ex whit factory rocker Ratio
Is it to much lift for the stock valve springs? Any coil bind?
Is the stock ones to soft? Valve float?
And can i run the stock rockers?
And if i change the springs, anybody know know if the installed height would be fine if i just swap them?
I actually have everything, except rocker arms, so its not really a big problem IF i need to change them. So feel free to think im asking stupid questions... haha
Outside diameter on new springs are 1.230 inch, same as stock?
Do they fit stock heads and retainers and such?
I could buy new rockers at the same time and change those att the same time though.. But then i need to wait for them to come... (live in Norway..)
Im actually doing this because my timing chain has started to rattle, so why not upgrade everything i thought :cool:
