Running Lean - FirebirdV6.com/CamaroV6.com Message Board
Running Lean
  • #16
    Re: Running Lean
    iv got 1.7k kms on it.....the cars running fine ....no codes or any thing.......its just dat i opened all my spark plugs and they r kinda white rather than light brown....or even black.....its a 5 speed..
    • #17
      Re: Running Lean
      1.7k kms as in 1700KM? That's hardly 1k miles.. are you talking engine or car?
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
      • #18
        Re: Running Lean
        oooh ma bad.........170 000 km
        • #19
          Re: Running Lean
          are you getting a code? it could be your 02 sensors. Are you leaking anywhere? manifold? headers? egr? is there a vacuum leak? any of that would cause u to run lean.
          • #20
            Re: Running Lean
            i checkd the sensors.....no leaks of any kind.......its just wat i think is......dat due to increasd air to the UIM the injectors are not being able to provide with the fuel.......caz iv got the stock tune with the most upgraded ignition......accel coils,8 mm wires, and NGK iradiums
            • #21
              Re: Running Lean
              that does not make any sense at all.
              you should be running better with an upgraded ignition system.. I have a 3.4 with MSD coils, Taylor Pro Wires, and platinum NGK plugs and it runs fine.
              get it scanned to see where your running lean (if it's one particular side u may have a leak on that side or that side's o2 sensor may be shot)
              run some fuel injector cleaner through your car, you never know.
              I don't think TUNING your car has anything to do with this problem.
              • #22
                Re: Running Lean
                Originally posted by Blip55
                Well that sucks dude
                side note:
                NOS is an overpriced brand of nitrous injection systems
                fast and the furious is a good movie, but need to learn their damn terms
                there was nothing wrong with their terms, every time they said nos, they showed the holley brand.
                • #23
                  Re: Running Lean
                  dats wat i am trying to figure out......if all the plugs look the same....the car is throwing no codes.....it runs fine.....n yeah i normaly do throw da lucas injector cleaner...i was thinking to drop in 19 injectors...
                  • #24
                    Re: Running Lean
                    WE CAN REBUILD IT, WE HAVE THE TECHNOLOGY
