When I put my 36lb injectors in about 3 years ago, I broke one of the fuel rail bolts off on the passenger side, the one closest to the front. I pretty much snapped the head off. So it still sealed to the lower intake manifold. Fuel rail and injectors still worked fine without it bolted down. I want to switch out my upper/lower intakes and heads. I got the kit drill out which I'm going to try to use. If that doesn't work what would be my altenatives?
Removing broken fuel rail bolt
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: Removing broken fuel rail bolt
Fuel rail is good, I just need the bolt out, so I can remove the upper intake. My only Alt. if I can't get the bolt out is to drill it out, but I think it would damage the lower intake manifold as well, which I don't mind since I'll be putting on another set of upper and lower intake manifolds and heads. But I would rather save the manifolds if I could.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Drill her out as dead center as possible keep goin bigger if u get lucky it might (stress might come out with the drill kit or you may be able to pull it out in pieces)... worst comes to worse drill it out the next size bigger and tap her on a drill press once u get her out im sure any local machine shop could do that for next to nothing... Alot of those drill kits work fairly well u just have to be careful. goodluck
Originally posted by ssms5411When I put my 36lb injectors in about 3 years ago, I broke one of the fuel rail bolts off on the passenger side, the one closest to the front. I pretty much snapped the head off. So it still sealed to the lower intake manifold. Fuel rail and injectors still worked fine without it bolted down. I want to switch out my upper/lower intakes and heads. I got the kit drill out which I'm going to try to use. If that doesn't work what would be my altenatives?2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
