guys would I be able to just take the vacum line of the FPR. I am leaning out in higher Rpms......I am gonna drop in new injectors but till than would I be able to bump the fuel pressure by taking the vacum line out.....?
Fpr Ques
Re: Fpr Ques
Unplugging the FPR will not give you more fuel pressure at WOT. At WOT there is NO VACUUM going through the line . The FPR lowers the fuel pressure at idle and as the motor vacuum drops, the fuel pressure rises. Your manifold vacuum is 0 at WOT. Your car will run very rich at idle and foul the plugs with no vacuum line.
Briansigpic
