Do they make cams for the 3.4L camaro, like Gt cams or something else? And Can I put cams on with only an intake, headers, and cat-back exhaust system? Would I have to modify anything else to install it? What would be a average price to buy one and how much would installation cost? Would it be WORTH it?
Cams for 3.4L Camaro?
Re: Cams for 3.4L Camaro?
Expect $500-800 for a mechanic to install a cam. You can get them from Deltacams for a decent price. When you call, make sure they know you have SFI and need to have the timing tab (they should know by the year).
When you say intake, you mean cold-air and not manifold, right? - Because the upper intake manifold is a poor design on the 3.4's poorly designed iron heads.
Yes, headers are definately worth it, but can be very expensive to have a shop install them depending on where you go. Then the risk is there to break the exhaust bolts/studs and they will charge you for extracting them.
How much of the work can you do yourself?
Originally posted by aznelhs16comp kit? Can you give me all the info you have on it? Would I feel and see a difference using it? For 3.4 V6 1995 camaro?Last edited by SpeedingFirebird; 12-20-2007, 08:15 PM.
