A rev limiter limits how high you can rev your engine. I think, stock, it's like 5500 or 5800. Something like that. You'd change it so that you can rev higher, therefore producing power in the higher RPM ranges.
His typing is called camel casing and should only be used by programmers. ;)
I'm also as retarded about tuning as he is. I would assume you make this change with HPT and that it can also be done with an automatic transmission without causing damage to it or the engine?
2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
