Did some more work today on the car. Got rid of my crappy looking fuel Tee that I was using for my nitrous wet kit. Put in a barbed fitting and tightened it all up. Next setup will be getting fuel off the schrader valve instead.
Also got the bottles and fire extinguisher mounted and all so I am ready for carpet now. I just need to find a place that sells factory color carpet to match the interior. So far everything I have found just looks a shade or two off.
Here are the rear seat delete pics now (also notice I had the ttops off in March, ha :p ). :)
Looking good, I only see 1 solenoid for the bottle opener, I can't see the other side of the bottle on the pic. Are you using 2 bottle openers? Also are you going to put heaters on them with bottle blankets? I assume you are just asking. What size converter are you using?
yes I will have heaters and blowdown tubes on each of them. No blankets or openers. That solenoid is for the NX bottle heater sensor.
I just put my order in for the second heater and blowdown tube today. That is why you don't see them in the pic. ;)
I have my current bottle heater and blowdown tube from the single bottle setup sitting in the passenger seat actually, lol. Still have to rewire everything so that is why the heater is not on it.
I am running a PI vigilante 3000 stall. Should be a bit higher on the bottle but not too loose so nitrous will not blow through it
Did some work on the car today. I put on my TA girdle and stud kit to strengthen the rear end.
I also did some underhood appearance work by doing the !latch wire mod. This is where you took the hood latch that runs along the driver's side and hide it under the fender to clean up the engine bay. :)
Ordered up my carpeting for the rear seat delete. :woot: stockinteriors.com sent me samples and I found one that matched pretty close to the stock. :) Should be here in like a week.
oh christ udlose ure selling the cobra... well i think youre next step is a c5 zo6, lol, youre almost as bad as me, 97rs4life if you can get that thing to launch and hook it will go deep into the 11's have you thought about a transbrake possibly :naughty:
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
So when are you expecting to have this done and are you bringing it to norwalk?
want to have it all done by the 1st of may, but the hold up right now is waiting for the block to get finished by Lance. I am also getting some more parts in from aussie land, a gasket, throttle cable bracket, and some other small stuff.
Just saw it on Facebook, looks awesome. The front and rear nice looking....
