compatible MAF without tuning? - FirebirdV6.com/CamaroV6.com Message Board
  • compatible MAF without tuning?
    I modified my 1997 3800 throttle body due to clearance reasons and cut off the section that houses the MAF. (The engine is in an isuzu pickup) I had been planning to run megasquirt for fuel and ignition control, which does not require a MAF.
    I'm contemplating switching to the OEM EFI/ignition setup so I would need to plumb in a tube-style MAF. Has anyone found one 100% compatible with this ECM that I could plumb one in the intake tubing?
    I understand you can make any MAF work by tuning but I am trying to switch back to stupid-simple and not get involved with HP Tuners, etc. Wiring changes are no problem but just looking for a MAF with the same output as the OEM one.
    Switching back to the OEM throttle body and MAF isn't an option.
    Chris<br />92 Isuzu pickup, dropping in a 3800
    Re: compatible MAF without tuning?
    no, you will have to change the maf tables with any of the other mafs as they flow differently. You may be able to find a calibrated maf though and then tuning would not need to be done. I just picked up this MAF for my build:
    I have to load a v8 table for it to work but I have hptuners. :) Oh yea and it has the IAT sensor right in the unit so I don't need to have a seperate sensor anymore either. ;)
    http://www.bowtiev6.com/
      If I go this route, of using an OEM ECM, it wouldn't be all that crazy to just tell the company I buy the ECM from which MAF I'm using and have them do the tune for me right?
        So what is it out of?
        Raven
          this is listed for 95-02' 3.8
          http://store.summitracing.com/partde...5&autoview=sku
          edit: looks like they messed up, also listed for V8
            you still need to tune the PCM for that MAF.
              The MAF I bought is a brand new 02 Vette MAF. 85mm in size and IAT built in. Also can be found on trucks
