sorry searched and couldnt find the answer...with the Gt2 cam can you still pass emissions?
GT2 Cam
GT2 Cam
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: GT2 Cam
1)run Autolite 606 plugs, the stock heat range
2)make sure you have a DAMN good tuner who knows how to tune the **** out of the VE table to smooth it out as much as possible.
3)keep all of your stock emissions equipment.
4)Advance the timing at cruise and idle. I made a hybrid table with the 2004+ Grand Prix GTP's and L36's in order to keep the 28 or so degrees of commanded timing at WOT, while managing 44-ish degrees of timing at cruise to help the MPG.
cross your fingers and hope you pass the sniffer. It has a lumpy idle. I had one in my old 99 Camaro and just tuned a 2000 Monte Carlo SS with one and got it to smooth out rather nicely, but if you listen you can definitely tell the car is cammed.Last edited by Fredless; 01-12-2008, 09:56 PM.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
Re: GT2 Cam
I realize it has a lumpy idol...thats what I want...but this is also my DD and emissions here is required every 2 years via the sniffer...so I NEED it to pass emissions...this is a huge deciding factor on getting this cam....the guy installing it would be tuning it, and apparently he is one of the best F-Body tuners around...atleast according to the guys over at Ls1tech.com
Re: GT2 Cam
I'd be getting it dyno tuned...Id have the original PCM but I doubt the car would even run with that since I hear it misfires and wants to die unless tuned...I abosolutely 100% need the cam to pass emissions if I get it...otherwise I need to be looking into a different cam, or forgo getting one...
Re: GT2 Cam
Originally posted by LETZRIDEI'd be getting it dyno tuned...Id have the original PCM but I doubt the car would even run with that since I hear it misfires and wants to die unless tuned...I abosolutely 100% need the cam to pass emissions if I get it...otherwise I need to be looking into a different cam, or forgo getting one...
Re: GT2 Cam
Originally posted by xmetallicaxguitaristxIdk man i've heard it can go both ways.. half the people have no problems and it runs fine... obviously it will be better with a tune, but some people's idles too low and dies.
but will that cause the car not to pass emissions?
Re: GT2 Cam
Originally posted by xmetallicaxguitaristxI've always lived in FL so I don't know **** about emissions.
Re: GT2 Cam
they use the OBDII port
Re: GT2 Cam
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
