So, there's a weird sound coming from my motor. I took a sound clip of it and want your guys opinion. My uncle thinks it's a cracked piston skirt. At first I thought it was a rod, but my oil pressure is perfectly fine? Is it possible to still have good oil pressure if it's a rod? I also noticed some white smoke from the exhaust. I put abit of wax on the tailpipes before I started it (was cleaning the car, and figured I'd take the clip), and there was water up in there, so I don't know if that's what it is, or if it's coolant. She's been sitting for almost a week now, and I need to get her fixed.
Knock Knock!
Re: Knock Knock!
Originally posted by nightrider2could be a dead lifter...i does go away when you rev it....check the oil pan for dents~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Knock Knock!
Originally posted by camaro9407what kind of cam. whats the lift and duration it could be opening the valves too far or for too long and that would be why it goes avay as you rev because the timing changes.
Man, watch the video... IT DOESNT GO AWAY as it revs.*Matt
Re: Knock Knock!
Originally posted by StrtRacer98Man, watch the video... IT DOESNT GO AWAY as it revs.Last edited by RadRacer; 01-20-2008, 10:36 AM.~97 3.8L V6 Camaro~
A few things
Re: Knock Knock!
It could be a lifter I have had it the last two winters. Just change your oil with a 5w 30 and lucas oil stabilizer. This has fixed mine both times. Is the oil you have now a 10w 30 ? and many miles old is it. Also does the sound go away when warmed up or when your drive it down the road alittle?
Re: Knock Knock!
ask around. have you flowbenched those heads. ls1s cant even use a 500 because its stupid they reach max flow at 450. i know your heads do not flow as good as ls1 heads. that may verywell be your problem. your stock cam is like a 200-250 i believe so the engine was built around that and now you are opening up the velves twice as deep and they probably are hitting the pistons.cant wait till my lt1 and nitrous.
Re: Knock Knock!
Originally posted by camaro9407ask around. have you flowbenched those heads. ls1s cant even use a 500 because its stupid they reach max flow at 450. i know your heads do not flow as good as ls1 heads. that may verywell be your problem. your stock cam is like a 200-250 i believe so the engine was built around that and now you are opening up the velves twice as deep and they probably are hitting the pistons.
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
