engine removal help asap - FirebirdV6.com/CamaroV6.com Message Board
  • engine removal help asap
    99 3800 auto
    everything is ready to pull out the drivetrain except the passenger motor mount is being a pita
    I'm pretty sure I have to remove the air condition pump to get the bolt out but i cant figure out how to get the damn pump out, got the 3 bolts off the front, all lines are disconnected but it is still in place, it move a bit when i pull on it and such but it's not going anywhere, are there bolts on the back? i'm pretty sure this pump needs to come out but if it doesn't and theres another way let me know
    thanks
    1999 Camaro Z/28
    1973 Firebird Formula
    Re: engine removal help asap
    I'm in process of removing my 3.8 out of my 98 bird. The AC pump had 2 bolts on the back also, kind of on bottom. I was going to pull out top, but have decided to drop K member and go out bottom.
      you will need to remove the A/C to get it out the top, cant remember the position of all the bolts.
