this is not related to the v6 camaros, but a general question.
basically i have a 355 with a comp cams 280h cam.. im thinking of going bigger, but i have some concerns
the block is milled down, and the pistons are domed
the specs of the current cam are 230 duration @ 50 and .480 lift
im thinking of getting a 292 comp cams magnum (or the cam similar to that) but im afraid that a valve might get murdered by a piston
its got the 462 heads on it also.. is there any way i can find out if i can run a bigger cam with no problems?
