Hybrid almost complete (pics inside) - FirebirdV6.com/CamaroV6.com Message Board
  • Hybrid almost complete (pics inside)
    Specs:
    Shortblock:
    1995 Camaro block, rods and pistons,
    ARI .010" under crank,
    Clevite77 main and rod bearings,
    Sealed power cam bearings,
    Stock replacement oil pump,
    Stock replacement timing chain,
    Cam (int/exh):
    230/236 duration, .510/.520 valve lift, 110*LSA with a 4* advance (all at .050")
    New lifters
    Top end:
    2004 3500 heads ported, polished, flat to .0005",
    1.6 aluminum full roller rockers,
    LS6 yellow valve springs,
    LS1 shims/seats
    2004 3500 lower intake ported to a 2.5" area at the top and gasket matched on the bottom - runners polished the full length to a mirror shine,
    2004 3500 plenum, also ported to 2.5" area, polished exterior
    TB:
    Undecided, a ported Ford 65mm unit is pictured, but have a 70mm in mind (will have to port the plenum neck).
    Valve covers are polished to a mirror shine (plenum has fingerprints on it, lol). Both will get a touch-up polish and laquered before installation into car.
    What do you think...
    More pics here:
    http://s158.photobucket.com/albums/t...ild/?start=all
    Desktop Dyno projects this engine to be 318bhp at 7000rpm (7200 redline). It's going in my third generation Firebird...
    Re: Hybrid almost complete (pics inside)
    VERY NICE! I can't wait to see 1/4mi and dyno numbers. 318hp should get you around 270 rwhp, thats around 14 flat in the 1/4. I'd say not to shabby for a N/A, 12 valve pushrod, 3.4L V6 (with a flat tappet cam might I add).
    BMW's new 335i has 300hp and they're using a turbo to that. I wonder what it feels like to spend $40K on your new turbo bimmer to get spanked by a N/A V6 FBody :rock: .
    Anyways, awesome job, I love the attention to detail you put into this project!
    Where in South FL are you, if you don't mind my asking?
      is that a 3.4 block ?
      1997 Camaro LS1 RS
      1994 Camaro - Sold
      1999 Trans am Vert - Sold
      A Few Mods....
        its a 95......no its a 3.1
          BAH that stuff isn't bolted down
            looking good man. Nice shiny valve covers too :)
            http://www.bowtiev6.com/
              Your right, the cam will be here in a couple days, need to get to the lifters, lol.
              All V6 Fbodies were 3.4's in 1995 ;)
              It's replacing a turbo 3.1.
              After I make a few runs (and hope for dyno pulls), then I'm replacing the 3.4 for 3400 pistons and turbocharging it again - leaning towards twins since I already have one.
              My machine shop is in Deerfield, I live in Coral Springs.
                Sounds awesome! Will this have a power adder?
                  Not yet, read previous post ;)
                    that is not true. They did make a handful of 95 3.8l cars late in the production year. So a 95 could be either a 3.4 or a 3.8l ;)
                      OK, only 60* :P
                      Got a link to your pics? I want to see how your Aussie stuff is working out.
                      EDIT: Nevermind, you have fquick too...
                        1 I was joking....being sarcastic...
                        2 Your wrong....3.8s were available in CA emission cars
                          :P I was already corrected by 97rs4life.
                          The buyer did back out of the 3.1, so I'm going to make it a hybrid as well for a backup engine :D
                          I figure I'll make an external DIS wheel on the CNC, could also be used when I get a tubular k member and put a full 3500/3900 in. A guy in Tampa just finished a TT 3900 swap into a Fiero, curious to see what it's going to do - and can use some of his developments.
                            beautiful! im still hoping to do the swap myself :)
                            the day i gave up hope my buddy replied and said to just let him know when i wanted to do it. haha.
                            i definitely want to see a video of this in action when it all gets done O.O
                              :D
                              and the cam specs...
                              Not as big as I wanted to go, but the price was right.
