Pulling Out Engine - FirebirdV6.com/CamaroV6.com Message Board
Pulling Out Engine
  • Pulling Out Engine
    Hello I'm A New Member And I Have A '94 Camaro 3.4 V6, 5 Speed.
    I'm Going To Rebuild The Motor And Was Trying To Find Out If I Can
    Pull The Engine Out The Top , Has Anyone Done This ?
    Re: Pulling Out Engine
    it wont come out the top unless you separate from the transmission
    i took the upper intake, AC, exhaust y pipe off
    1999 Camaro Z/28
    1973 Firebird Formula
      Thanks, I've Done Other Cars & Trucks Before, But Everyone I Talk To Said On Fbody Cars It Has To Come Out The Bottom---drop The Subframe Cradle.
        It will come out the top but it will be a pain in the ***.
          you just have to take just about everything out of the front and she will come out with a little movement
          WAWA-A-HOLIC
            I got my engine to come out by playing YMCA. The motor started danceing and I said to the motor "your gay aren't you?" and the motor came out admitted it. I knew it was gay bacause if it wasn't it wouldn't be a v6, it would be a straight 6. Ha sorry. So what is the best way to pull the motor if you have no lift?
              Have You Done This On Your Car?
                Viper has a pic on the other forum pulling the motor and tranny from the top. I think he just took off the upper intake manifold off.
                  just pull it from the bottom....its much easier
                    If you are going to rebuild the engine you should go ahead and do the top end swap.
                      I've done both top and bottom (after niik000's post that doesn't sound right). Anyways, you can get the engine out of the top, however it's easier to do everything through the bottom because you can basically remove the engine assembled and put it back in assembled. The only thing you really have to take off is the A/C compressor (assuming you don't want to evacuate the system), disconnect the driveshaft, brakes, exhaust, hoses (including fuel lines) and wiring. Then the whole assembly comes out the bottom. If you don't have a lift, I've seen people use a cherry picker and wrap a strap around the front nose (bumber cover to behind the radiator). I used a forklift and jackstands and lifted it by the radiator core support (just don't try to do that with the engine in, it'll probably bend).
                      It's much easier to work on the engine outside the car than inside the car.
                        Hey -- Thanks For The Information
                          We pulled the engine in my 94 3.4 firebird while leaving the tranny on by lifting the front end up on standsand and tilting the back end of the tranny down. its a pain in the *** but even harder to get to the upper tranny bolts. i would reccomend pputting it back in like that also
                            We pulled the engine in my 94 3.4 firebird while leaving the tranny on by lifting the front end up on stands and and tilting the back end of the tranny down. its a pain in the *** but even harder to get to the upper tranny bolts. i would recommend pputting it back in like that also
                              this is from my 00 bird, but its the same principle, its really easy this way.
                              Team NoVa
