Ok im doing an engine swap on my 96 3.8 camaro. i allready got the old engine out by dropping it out the bottom. i unplugged all of the plugins going to the motor from the car harness, question is, did i have to do this? it looked like a bunch of wires went up under the dash, and i didnt want to mess with that. so can i plug in all the sensors to the motor out of of the car and drop the damn thing in there and just plug in a few things under the dash?
Unplugging harness
Re: Unplugging harness
just plug in whatever you took off of the old engine. You shouldn't have to mess with anything under the dash unless you went to a ls1 instead of your 3.8
hard to tell what you have circled in the pic, what sensors are they? That would help us tell ya
