how hard is it to install a cam i looked but i coudnt find anything on it. im very mechanically inclined so i know i can do it whatever it takes. but does the engine need to be pulled out to acess it if so forget it
camshaft
Re: camshaft
engine can stay in. you would need to remove the radiator to make enough room to pull it out.
Re: camshaft
yes you would need tuning after a cam install unless you went with a small cam.
Here is a good writeup
http://www.dxsoftware.com/magnus/v6headscam.htm
Re: camshaft
Originally posted by mobilelectronics View Posthow hard is it to install a cam i looked but i coudnt find anything on it.
^look harder
Originally posted by 97rs4life View Postyou would need to remove the radiator to make enough room to pull it out.
Originally posted by mobilelectronics View Postas far as gas mileage goes am i going to loose alot or just a little.
i have to get the timing redone after i pull it out right?
is there any kind of guide on the camshaft.
^again, sticky at the top of the forum
Re: camshaft
sure if you want it to be a tighter squeeze, leave the radiator and fans in there. I would prefer to have enough room to work with. At least take the fans out of there to give more room
