how hard is it to install a cam i looked but i coudnt find anything on it. im very mechanically inclined so i know i can do it whatever it takes. but does the engine need to be pulled out to acess it if so forget it
camshaft
Re: camshaft
engine can stay in. you would need to remove the radiator to make enough room to pull it out.
Re: camshaft
yes you would need tuning after a cam install unless you went with a small cam.
Here is a good writeup
http://www.dxsoftware.com/magnus/v6headscam.htm
Re: camshaft
Originally posted by mobilelectronics View Posthow hard is it to install a cam i looked but i coudnt find anything on it.
^look harder
Originally posted by 97rs4life View Postyou would need to remove the radiator to make enough room to pull it out.
Originally posted by mobilelectronics View Postas far as gas mileage goes am i going to loose alot or just a little.
i have to get the timing redone after i pull it out right?
is there any kind of guide on the camshaft.
^again, sticky at the top of the forum
Re: camshaft
sure if you want it to be a tighter squeeze, leave the radiator and fans in there. I would prefer to have enough room to work with. At least take the fans out of there to give more room
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...18 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
