camshaft - FirebirdV6.com/CamaroV6.com Message Board
camshaft
  • camshaft
    how hard is it to install a cam i looked but i coudnt find anything on it. im very mechanically inclined so i know i can do it whatever it takes. but does the engine need to be pulled out to acess it if so forget it
    Re: camshaft
    engine can stay in. you would need to remove the radiator to make enough room to pull it out.
    http://www.bowtiev6.com/
      Re: camshaft
      ok i like the sound of this. as far as gas mileage goes am i going to loose alot or just a little. i really love the sound of cam. i have to get the timing redone after i pull it out right? is there any kind of guide on the camshaft.
        Re: camshaft
        yes you would need tuning after a cam install unless you went with a small cam.
        Here is a good writeup
        http://www.dxsoftware.com/magnus/v6headscam.htm
          Re: camshaft
          http://forum.camarov6.com/showpost.p...04&postcount=5
          ^look harder
          No, you don't.
          Depends on what cam you get and your driving habits
          You're gonna have to get more than that redone
          http://forum.camarov6.com/showthread.php?t=46236
          ^again, sticky at the top of the forum
            Re: camshaft
            im pretty sure this only applies to the v8 engines
              Re: camshaft
              sure if you want it to be a tighter squeeze, leave the radiator and fans in there. I would prefer to have enough room to work with. At least take the fans out of there to give more room
