MS quote - FirebirdV6.com/CamaroV6.com Message Board
MS quote
  • MS quote
    ok this is what i was quoted for a complete MS setup, i didn't know were else to put this info but i thot others would like to see it.
    A MS-II will work great for controlling fuel and spark. If you are
    completely replacing the stock ECU, you can use your stock temperature
    sensors. If you're leaving the stock ECU in place, you'll need to give
    the Megasquirt a second set of temperature sensors. I'll quote you for
    what you need with the sensors.
    Here’s a quote for a pretty complete system with the ECU/Stim un-assembled:
    MS230-K $247 Megasquirt-II kit with V3.0 PCB
    MSStim22-K $45 Stimulator kit
    MSHarness $65 12' wiring harness
    CLTIATwPiggy $17.75 Coolant temperature sensor
    IATwPiggy $22.25 IAT Sensor
    38NPT-Bung_S $8 Bung for mounting IAT sensor (steel weld on, or JB-Weld on)
    TuneCable $5.50 6' DB9 tuning cable
    USB-2920 $20 (Only needed if your laptop doesn’t have a true DB9 port)
    Subtotal without wideband-- $430.50
    And here’s a quote for a pretty complete system with the ECU/Stim
    assembled:
    MS230-C $410 Assembled Megasquirt-II with V3.0 PCB
    MSStim22-C $69 Assembled Stimulator
    Subtotal without wideband-- $617.50
    The wideband oxygen sensor is a very useful tuning tool. Almost all dyno
    shops have wideband sensor systems they can install temporarily when
    tuning your car on the dyno. If you plan on tuning the engine yourself,
    it will be very helpful to have a wideband of your own. Megasquirt works
    with most popular aftermarket wideband oxygen sensor controllers. We
    carry the Innovate Motorsports line.
    Wideband Options—
    LC-1 without gauge $199 (you can still view real-time AFR and datalog
    AFR through your laptop)
    LC-1 with 3731 analog gauge $258
    LC-1 with DB digital gauge $289
    LC-1 with G2 or G3 analog gauge $289
    LC-1 with XD-16 digital gauge $399
    LM-1 with built-in LCD Readout $349 (good for tuning multiple cars, temp
    installation)
    I think this will give you a pretty good start in the right direction.
    If you’d like to place an order, you can do so at
    www.diyautotune.com/catalog and it will calculate exact shipping costs
    (based on weight of your order) and accept all major credit cards
    securely. If there is anything else I can assist with, please just let
    me know!
    Thanks,
    Matt Cramer
    DIYAutotune.com Technical Support
    Please reply with history, as this will help me look up what we have been discussing and respond to you faster.
