Alright so I'm finally digging into my engine. Right now I'm just at the valve covers but I'll be changing the valve springs when I do the rockers. When I was removing.. or bending.. that damned passenger side lift bracket I was looking and it really didn't seem like I'm gonna have room for my valve spring compressor tool. http://store.summitracing.com/partde...2&autoview=sku That's the same type I bought.. I never thought of it before but it looks like it'd be a pain in the *** if even at all possible to use that. Just wondering if anyone has actually used one like this with the heads still on without problems or should I look for another tool? If I'm gonna need another tool, which tool has specifically been handy with our engine bay?
Valve Spring Compressor Tool
Re: Valve Spring Compressor Tool
I got the Habor Frieght one, works good.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I don't see what the big deal is about that bracket. Mine came off easily?!? From underneath with a ratchet, I broke it loose and they came right off.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Air compressor and fitting for the spark plug hole is what most people do to keep the valve from dropping, thats what I'll be doing.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
The tool you bought will prolly work, just be ready to make some slight modifications to it to allow for some clearance. as for keeping the vavles from dropping, you can get a peice of nylon rope, pull the plug out, and feed a coule feet worth into the cylinder. its cheap and very effective.
Originally posted by lilchubby View PostThe tool you bought will prolly work, just be ready to make some slight modifications to it to allow for some clearance. as for keeping the vavles from dropping, you can get a peice of nylon rope, pull the plug out, and feed a coule feet worth into the cylinder. its cheap and very effective.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
TEAM C6V6
