what is most likely to break when reving in the 6500-7000 range?
high reving engines
Re: high reving engines
theres a whole bunch of things that can break.
Follow me!
Or this
Originally posted by lilchubby View Postif i had my guess i would say either (a)breaking a valve spring, and dropping a valve, (b)bending a pushrod (a)lifter collapsing....with the probability going a, b, cyou went a b a, not a b c
Someone needs to relearn their alphabet :)
As for issues, it's generally valvetrain parts. Lifters, pushrods, springs, valves (imagine that, it's part of the valvetrain :P), etc. I think for the most part, our bottom end is fairly strong and, IIRC, no one has broken it just from brute power.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
