head issue help - FirebirdV6.com/CamaroV6.com Message Board
head issue help
  • head issue help
    I just bought this car a week ago it had a blown head gasket. when taking the motor apart i realized that it was missing a head bolt. after looking the reason is the bolt hole has been wallowed out. i tried a hellicore but the hole is to big. any suggestions?
    Re: head issue help
    Try a King-sert they are a bit larger then Heli-coils. If that doesn't work find a bolt that is big enough to fit in the hole, cut it off flush. Then drill and tap that to the head bolt size.
      Re: head issue help
      i'll try that thank you.
