Alright, I think theres something seriously wrong here, there's oil coming out of the exhaust when I rev it, the exhaust smells like unburned fuel and/or burning coolant, I think theres oil in my coolant reservoir, idle speed is 1500 rpm and the car shakes when it's idle.
This just sounds like loads of fun doesn't it?? :stp:
From what that you just mentioned i think it maybe bad Piston rings, and bad head gaskets. That would be my first guess. If oil is in your exhaust then it can be that the oil rings on the piston are bad and that can cause the oil to get by. Also is there smoke coming from the tail pipe when the car is on?
Sort of, it's not really bad and it's inconsistant.
I'm like 99% sure it's oil, in the winter i thought it was just condensation which is normal, but i'm pretty sure it's oil.
Okay... I just thought we might be able to eliminate everything real quick. Dad's truck has blackness coming out of the exhaust sometimes, but its just gunk built up with the condensation... you can tell by the smell of it. Good luck with whatever it is.
Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
More than likely you would need motor rebuild if the rings are bad hopefully it's something else and it can be a easy fix but just take it apart to see whats wrong with it.
most likely the rings gouged the cylinder walls beyond repair. If the motor is chugging oil it is seriously hurt, possibly even gouged through to an oil passage thats pumping into the cylinder.
