Having my Firebird rebuilt and brought back from the dead and the mechanic I have doing to rebuild seems very savy comes highly recommended. He does allot of funny cars, sand rails and hi performance builds out here. Anyway as we were talking he sold me on flat top pistons and having the head decked, I wasnt quite sure what this is. I felt kind of dumb cuz I thought i was pretty tech savy and didnt ask anyway just curious if someone could explain this to me lol thanks.
heads decked?
Re: heads decked?
I believe this is just milling the heads to either get a more of a flat surface or to up the comp. if your going for more Hp.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: heads decked?
It sounds like he wants to up your compression. Our pistons stock are dished right (I'm like 99.9% sure they are I forgot though)? Did you just want a stock rebuild or do you want a faster firebird? IMO while the engine is getting rebuilt you should add some toys if you know what I mean.
Re: heads decked?
Yes, he's doing some other upgrades for me nothing major but supposed to add about 30 ponies whens all done and said. I should end up running with the compression at around 10:1 further down the road I would like to add a turbo with some mild boost, so I didnt want to get the compression up there.
Re: heads decked?
Im not looking for monster turbo power just more pep. Who knows maybe with the internal work and a new exhaust system and headers I'll be happy. Maybe a nitrous system would be a better way to go. That was my original plan but after doing more research I figured I would end up spending alomst a comparable amount on a nitrous set up as i would on a turbo.
Re: heads decked?
Nitrous does like compression.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: heads decked?
You better make sure that the "decking" and flat top pistons will allow for proper valve travel or you're going have a mess when you start it and ram the valves into the top of the pistons!Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Re: heads decked?
Originally posted by xmetallicaxguitaristx View PostAnd if the heads aren't milled PERFECTLY straight you could have just as big of problems.. IE the camshaft snapping or getting extremely worn very fast, and more forward pressure (trying to leave the engine) because the whole valvetrain is off-center.
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
Re: heads decked?
Originally posted by xmetallicaxguitaristx View PostWell he would just have to get an extremely efficient turbo + intercooler
