which cam should i get? i'm getting hp tuners vcm suite.
cam
Re: cam
Custom grind.
No but seriously, what are your future plans, and how much $$$ are you willing to spend? If you want to go all out N/A and get a huge cam, you'll need to pretty much upgrade every single part in the valve train. If you are planning on doing a power adder in the future you need to mention that too.
