Dropping oil pressure as I drive/smell of burnt oil - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Dropping oil pressure as I drive/smell of burnt oil
    lol glad you found out the prob, i had same prob but a good oil change and cleaning fixed it.
    • #17
      Ah older.. I'm out of my element anything pre 98
      TEAM C6V6
      • #18
        No cleaning needed, replaced the sending unit for 24 and some change, then a oil change and it seems to have cleared up, we'll find out tomorrow when I take it to get inspected and test drive
        lol its coll brudduh you was only tryinna help
        • #19
          an oil leak isn't going to make the oil pressure drop when driving; i've got a rear main seal leak and the pressure stays at about 60 even at high rpms. your motor is just worn the f**k out if the pressure drops below 60 at over 1000 rpms. below 1000rpms the pressure may drop a little but should stay at 60 while driving. my advise; drop and ls1 in it
          • #20
            My advice is check the thread date dood lol. I've done corrected this problem. lol
            • #21
              Ooooooooo. lol
              TEAM C6V6
              • #22
                well that's good
