Valve Springs - FirebirdV6.com/CamaroV6.com Message Board
Valve Springs
  • Valve Springs
    Anyone know the ID, OD, spring height, etc of our springs and/or LS6 springs? I'm looking around locally for a set of valve springs, and asking for LS6 springs isn't exactly cutting it :P. So, anyone know the dimensions?
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Valve Springs
    summit has the specs on the comp 105 and 130 lb springs
    http://store.summitracing.com/partde...5&autoview=sku
    I don't think it lists the free length, but for stock springs 1999 and earlier is 1.981 inches and for 2000 and later it's 1.960
      Re: Valve Springs
      That's what I was looking at before, but I wasn't sure if they were the same as the LS6's. I've got the retainers, just need a set of springs now, and, like I said, everyone's asking for spring specs, not what they came from.
      EDIT: http://store.summitracing.com/partde...5&autoview=sku
      Are those stock LS6 Springs? I didn't think they were double springs; the ad says they are, even lists ID for both springs, but the picture only shows a single spring.
      ~97 3.8L V6 Camaro~
      A few things
        Re: Valve Springs
        yeah, weird. the pictures i've seen were not double either. i think summit might have messed up.
        i understand why after some research. GM part number in '03 was 12565117, in '04 was 12565313. Now is 12586484 and for a package of 16 is 12499224.
        EDIT:
        Also found this. Looks like there are multiple LS6 springs.
        "2001 LS6 springs had a blue stripe for .525" lift superseeded by Yellow stripe on the 2002 springs and puke green color stripe on the 2003 LS6 valve springs rated for .550" lift"
          Re: Valve Springs
          o well, guess I'll just stick with an online order. How hard is it to install valve springs with the motor in the car?
          ~97 3.8L V6 Camaro~
          A few things
            Re: Valve Springs
            not too bad. this is what I have.
            Spring compressor
            http://www.sears.com/shc/s/p_10153_1...pecialty+Tools
            Air hold fitting
            And a little pen magnet for the keepers.
              Re: Valve Springs
              I like the air fitting for the spark plug hole, I wish I had that when Meatyshells and I did my springs. On one or 2 of the plug holes it was difficult, we finally ended up buying a 90degree adapter from ACE just to get to them I had only the straight air fitting for the spark plug holes. Good info.
                Re: Valve Springs
                You should get some rockers while you're at it! If you don't already have some..
                TEAM C6V6
                  Re: Valve Springs
                  Stockers are fine. I was debating going with some 1.7's, but the price vs gain isn't worth it.
                  ~97 3.8L V6 Camaro~
                  A few things
                    Re: Valve Springs
                    Yes it is! Btw, why are you putting in stronger springs?
                    TEAM C6V6
                      Re: Valve Springs
                      GT2 Cam
                      ~97 3.8L V6 Camaro~
                      A few things
                        Re: Valve Springs
                        105# is what ZZP recommends in their description of the GT2 cam.
                        1999 Firebird Y87/W68
                          Re: Valve Springs
                          buy my 1.9s.....
                            Re: Valve Springs
                            lmao 1.9 with a gt2 cam, bye bye valve covers?
                            TEAM C6V6
                              Re: Valve Springs
                              Meaty, don't quite think they'll work :P. 1.8's is the highest I can run, and that's with modded retainers, and locks from ZZP, and it's still slightly above their recommended limit.
                              ~97 3.8L V6 Camaro~
                              A few things
