It's Alive!
Re: It's Alive!
Went and had the codes scanned, just to be sure I'm safe. I was expecting the cam code (ZZP says it throws it, not sure which one, but it wasn't there) and an O2 code (no cat), but what I didn't expect was a Cylinder 6 misfire. Brand new NGK TR55 plugs; I ran these before in the other motor and it ran perfectly! I figured maybe the wire wasn't on right or something; reach through the headers and pushed on the cyl 6 wire and I hear it snap into place, thinking I just solved my misfire :). Wrong :(. It misfires under load now, not at idle though. I didn't notice anything wrong with the wires (almost new, rougly 3K on them, OEM replacements). I'm letting it cool right now so I can actually reach that plug/wire, and recheck them, and then check my coil. Any other things I should check?~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: It's Alive!
OK, checked my coil, and either that's definitely bad or it's my ICM. It doesn't have a constant spark, it's completely random. I'm hoping I can get a new one today and fix it.~97 3.8L V6 Camaro~
A few things
Re: It's Alive!
Replaced the coil and that's not the problem. I'm havin my Uncle look at it this afternoon; he's a mechanic for the county, so he's got an idea what he's doin :P~97 3.8L V6 Camaro~
A few things
Re: It's Alive!
Found the problem; it usually helps if the injector's plugged in :). She's running beautifully now. Doesn't miss a beat, gets swirly hitting 2nd, pulls like a mofo, and sounds amazing :)~97 3.8L V6 Camaro~
A few things
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.4 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
