problem after cam install - FirebirdV6.com/CamaroV6.com Message Board
  • problem after cam install
    got everything all pieced together, and it fired up right away, it sound great. didnt have any leaks or anything.
    Drive it down the street, around the black come back everything is fine. I let it idle in the garage for a while then turned it off and went and took a shower.
    Start the car back up and then drive to my work 15 min away, all highway driving. i pull into a gas station and the car dies on the way in. I pump gas and now the car doesnt want to start. It tried really hard. I let it sit for a little while. Started it up and it really struggled to start and i made it to my work, where it died as soon as i parked.
    tried to restart and it wouldnt start. So i disconnected the battery and let the car cool down for about 30 min. Go back out reconnect the batt and it fires up right away no problem. Then the car sounded good for a little and then the idle started getting really loopy and it turned off.
    I also thru a p0101 code.
    Im not sure what to think, im hopping it has something to do with tuning. Im thinking once the car gets hot it's not getting enough fuel.
    Re: problem after cam install
    P0101 is a problem w/ the MAF.
      but i didnt have any problem with it before the install. I didnt even take the throttle body off the intake. Checked all the connections and wireing, everything is golden
        Hmmm... just wondering here... hwo long does it take our cars to reach closed loop?? Maybe the stock tune cant compensate for the cam when actually listening to the sensors at closed loop idle
          just a thought, prolly has no relevance...do you still have the egr on the car?
          do you think that maybe when the egr opens it leans out the a/f ratio to the point where the fuel cant keep up wih the cam?
          im probably wrong but, its a thought
          Y87 Package
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
          Team Black...TEAM EMO
          Come on kids! Get a Calendar!
            If you can't amaze them with brilliance baffle them with bull**** right? j/k
            Let's flip a coin. Heads I get tail, Tails I get head.
              haha exactly. but in all seriousness, does anyone think that could do it? the egr would open at highway speeds as discussed and at anything above idle it would run fine....
              Y87 Package
              MOGOB APPROVED!
              BONE APPROVED!
              VANBIBBER APPROVED!
              KRISTEN APPROVED!
              Vice Prez.
                naw i dont have an egr. but yeah that does make sense haha
                im like 75% sure it has something to do with the tuning. I have an as$ load more air coming into the engine, and i dont think im getting enough fuel when the car warms up, or once the computer starts to learn whats going on, its seeing the big cam and doesnt know what to do. hence the easy start after the batt disconnect
                  that was my next call....need to tune your fuel trims!
                  Y87 Package
                  MOGOB APPROVED!
                  BONE APPROVED!
                  VANBIBBER APPROVED!
                  KRISTEN APPROVED!
                  Vice Prez.
                    Wideband woooo!
                    TEAM C6V6
                      fuel and air metering system is being goofy. is your cam kinda big? the MAP sensor will be goofy cause the vacuum inside the manifold will change with a larger cam.
                        ehhhh, i started the car up again, its starts right away with no problem, but it running really badly, sounds like somethings loose inside the engine. so im pulling it apart again :(
                        I have both intakes off, crank pully, and all the front cover bolts out cept for the ones that come thru the oil pan. Not bad for less than a hour and a half of work :)
                        but any way im done for the night, ill update tomorrow when i have the cover off.
                          ok i found the problem
                          in my deprived sleep last night i only had the bolt that holds the cam gear on finger tight . soposed to be 74 ftlbs + 90* haha
                          putting the engine back together as we speak
                            hope that was your problem, gl man
                              how big is the cam?
