When I got my heads back from being milled, bead blasted, and valve job I didn't noticed that they didn't have the freeze plugs on each side. So I ordered 4 at checker and I think the name was Dormain 1 1/8" frezze plugs, but these are the rubber insert kind instead of the steel and bronze. I went ahead and put them in and tighened the nut on the outside. Just wondering if anyone else has used the rubber type of frezze plug?
Freeze plugs for heads
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: Freeze plugs for heads
The rubber plugs are designed for TEMPORARY use. While they are often used long term, it's not a good idea. You would be best off getting a propper metal plug to press in there. In fact, you should take it to the place that did the heads. Most machine shops replace the freeze plugs on any head they do work on.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
I would take the heads back but they are across town. So it would cost me more in gas to have them put in 4 frezze plugs, I think they forgot to put them in since they are a good company to deal with. I'm going to look and see if I can get some steel ones to put in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I used rubber freeze plugs on my block and they hold up fine for dailey use but if you really get on it hard and build up internal pressure they will pop out. Then your looking for it on side of road or in your undercarriage somewhere and it just leaves you in a bad mood. Get steel ones if you can!Originally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
^ I'm just going to put in steel ones, but 1 1/8" steel won't fit , so I'm going to try the 1" steel plugs.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Hey Guys I have a little prob. My car overheated and since has been leaking water from the block. I thought my block would be cracked but a guy told me that only really happens in the winter. There is no water in my oil and no white steam out of the tail pipes so we think the headgasket is intact. A guy told me more then likley a freeze plug popped out. Would that cause my car to drip water out of the block and cause air to get into my cooling system. If so where are they, how many are there, and how do I check them
I know there are 2 on each head, one on front and back. The block has at least 2 or more.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I got the steel freeze plugs in yesterday. They were 1" steel plugs 4 of them. I used some rtv around them, then used a socket to hammer them in. So if someone does a search thats what I did to replace the freeze plugs on the heads. Off the engine of course.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
For future reference, the best thing to put on a freeze plug when installing it is GREEN Loctite and Loctite "Primer N". It's expensive, but works great for press-in stuff. Spray the primer on the block and put the green stuff around the freeze plug.Last edited by Skinny; 08-06-2008, 09:46 PM.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
I think my dad mention that but I had some rtv on hand so that is what I use. But I should of down it like ^ said above.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...1 day ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....5 days ago
