Can you swap an LS1 into an Pre-98 FBody - FirebirdV6.com/CamaroV6.com Message Board
  • Can you swap an LS1 into an Pre-98 FBody
    I know of a 96 in great condition that I can have for real cheap, and with $3.5K extra I can have an LS1 Motor and Trans. Of course I'll need a rear end and new fuel pump / fuel lines too - not to mention I have no experience in doing Motor Swaps ...
    Car - $1k
    Engine/Trans - $3.5k
    Rearend - $1k
    Fuel Accessories $750
    Installation - $2k ??
    Total - $8.5k
    Forget it, I think I answered my own question, unless someone can teach me how to do an LS1 swap.
    The problem is though, there's really no LS1's out where I live :(
    Re: Can you swap an LS1 into an Pre-98 FBody
    you can put an LS1 into anything
    ...and there's a local 3rd gen. w/ an LS1 in it, too
      ^the only way I would ever be caught driving a friggin miata^
      Let's flip a coin. Heads I get tail, Tails I get head.
        That would have to haul ballz man!
        Lounge Moderator
          It should be possible, both the LT1 and LS1 are 5.7L V8, the LS1 is probably a little more bulkier then the LT1.
          LS1 Mazda ftw!
            it's totally possible, but i dont think you'll be able to use the stock air box. i believe that's actually part of the reason the front end changed...the 93-97 hood didnt clear the LS1 air box.
            and you can find urself a fine V8 rear for Hella less than $1K...LS1 + trans should be alot less than 3.5K also, shop around man...
            that Miata reminds me of that 427 powered Miata Stacey David built on Gears lol
              I see, where would you recommend I look for these parts? Cheapest I could find was $3.5K on Ebay - everything else was around $5k
              Edit:
              I found one for $2.4K at tacreations.com - it has 172K Miles though -
              1. How much would I be looking at for a rebiuld?
              2. How much for a rearend? I was going to go for a 12 Bolt W/3.42's because I know the rearends in LS1 Cars are weak 10 Bolts
              3. How difficult for an average mechanic is it to install and what tools would I need? If it's something I shouldnt touch, how much would a shop charge me?
              4.Can I use the stock 96 Speedometer? I honestly would like to keep the 125 MPH speedometer...
              Edit #2 : Also I saw two 96 LT1's between $1,100 and $2,200 - Would it be more cost effective to just go use an LT1? Also as far as modding potential goes, How much more would I have to spend to get an LT1 to take out an LS1? Lets say, to get an LT1 in the 400 HP range?
              LS1's can do it with full boltons, but would I need a head/cam job with an LT1 to pull it off? Maybe just boltons and a P&P intake could do it?
                check out some places like TA creations. i've seen some early model (98-99) LS1's w/ trans go for 22-2400 bucks. check some boneyards too, even if you have to do some driving, the money you save may be well worth it.
                as for intake, you can get past the air box problem with a CAI...you can get thoooose....oooh, pretty much everywhere that sells anything
                check the "for sale" sections on some V8 Fbody websites also
                  nice mx-5, though my favorite ls1 swap is
                    yeah, I found two motors
                    An LS1 for about 2.4K and an LT1 for about 1.1K
                    Will the 1k of savings be enough to give the LT1 an edge over the LS1 or should I just go with the LS1?
                    Also
                    Where can I find a 12 Bolt for relatively cheap?
                      yes it will fit, with 8k you should just get a 98+ Z28 for that price.. unless you like tinkering with things..
                      MISC: 01 parts. Some interior, T top kit, seats etc.
                      http://forum.camarov6.com/showthread.php?t=95347
                        i know the fuel systems are different
                        1997 Camaro LS1 RS
                        1994 Camaro - Sold
                        1999 Trans am Vert - Sold
                        A Few Mods....
                          Why would you want to swap in an LS1 into a 96?
                          Id rather keep the 96 and go pick up a Z28 and have both!.
                            anyone have more info on the swap... i am tempted for 1 last project
                            1997 Camaro LS1 RS
                            1994 Camaro - Sold
                            A Few Mods....
