i want to plan ahead here for the winter, i'm gonna actually have my baby in a garage and not stored out on the back patio.
i was thinkin bout tossing a cam into my 3.4 as well as new springs,locks,retainers,double roller timing chain, probably a water pump, and replace all the gaskets and such along the way.
i found a kit from summit that has just about everything i need.
it's got the cam, lifters, springs, locks, retainers, valve seals and even the timing chain and more.
here, check it out for yourself.
http://store.summitracing.com/partde...4&autoview=sku
that doesn't seem like a bad price for all that it comes with.
I've already taken my 3.4 top end apart and installed 1.6 roller rockers and hardened pushrods so i've been around the block with this engine before.
the only thing new to me will be taking off the accessory brackets and obviously the timing chain and cam and all that fun stuff.
how does this kit look? I really think i'm gonna go for it.
if your familiar with Funkz's build up, this is basically what i'm going for, except of course the only difference being rocker arms, in which case mine are rollers and his are stamped.
any thoughts on my build up here?
also, i know the camshaft needs to have the cam lobe to be compatible with SFI engines, is this one gonna be ok?
