i found this 99 camaro engine with about 55,000 miles on it will it fit my 97 rs????
97 to 99 engine swap
Re: 97 to 99 engine swap
I would keep the angled TB and upper intake, the 97 TB's are eaiser to maintain when something goes wrong compared to the electronic TB's.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
The upper intake, maybe the lower(don't know might need the 97 one) and the angled 97' TB.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
It will work just fine, but you will have to use the upper intake and throttle body from the 97 because the 99 has an electronic throttle body.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
the engine is the same, the only difference is electronically controlled throttle body and cable driven throttle body, and different exhaust manifolds. use the exhaust and intake from your car, and the engine from the other car, they will interchange. you will still be using your PCM which won't throw any codes and your guages will still work.Team NoVa
