newer v6
Re: newer v6
egr valve. your 97 had it from the factory, someone took it off then
Re: newer v6
if you don't have it right now and you are using the same pcm then you are fine. it is for emissions
Re: newer v6
just make sure the computer is tuned for it. All it does is recirculate the old mixture that wasn't burnt into the engineCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Re: newer v6
Originally posted by v6mOtOrhEAdftOp View PostAll it does is recirculate the old mixture that wasn't burnt into the engine
Some good reading... http://sethirdgen.org/egr.htm'99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
'97 RS - HPTuner, Bolt-ons
'09 WRX - Aesthetic mods
Re: newer v6
Originally posted by Mr. Logger View Post1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: newer v6
Originally posted by loser View Postwasnt needed. newer ls1 motors didnt have it at all, they went with a slightly smaller cam and got away with out needing one. but they kinda cheated with using the AIR pump system though.Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Re: newer v6
Originally posted by v6mOtOrhEAdftOp View Postdang you beat me to it :(
if you block it off odd's are your'll set a SES light, mine did but its on for not having a rear O2 sensor so i didnt care.
dont buy block off plates, make your own. just need a drill and 2 peices of metal 1/4" is fine. i used copper gasket maker and havent had any leaks.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: newer v6
it resuses the air/fuel mixture to improve fuel mileage and also to cut down on engine tempsCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Re: newer v6
Originally posted by Mr. Logger View PostJust curious, because what you said, sound like there is unburned air/fuel mixture on one side of the engine... Which of course makes absolutely no sense.
when combustion temps reach a certain temp, NOx is created, its a toxic pollutant. the egr lowers combustion temps so that doesnt happen.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: newer v6
Originally posted by Mr. Logger View PostRight. I understand the idea. I'm just trying to figure out why he keeps calling it an unburned air/fuel mixture. It's exhaust gas that gets recirculated.
mine's only off becuase when i put my headers on i couldnt stop the exhuast leak from it, so i just blocked it off.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
