Pistons - FirebirdV6.com/CamaroV6.com Message Board
Pistons
  • Pistons
    Will forged pitons for the supercharged 3800 series II work in the n/a one. I imagine that they would but I just wanted to be absolutely sure
    Re: Pistons
    The supercharged 3800 are not forged they are a lower compression like 8:5.1, the L32 rods which replaced the l67 rods are forged. If your looking for forged pistons , I put in Diamind 9:5.1 forged pistons in about 6 years ago and their still going strong. They also came with Total seal piston rings.
      Re: Pistons
      do you have the part number for the pistons?
        Re: Pistons
        I got mine from Intense racing, also ZZperformance sells them.
          Re: Pistons
          if you want to get a little bit more power out of your engine you can get some high compression pistons.
            Re: Pistons
            I'm actually planning on running a turbo kit, that's why I want the pistons and I didnt know if i would need low compression pistons
