ok so i have an extra 3.4 in my room that i picked up for free. i want to build that up and then swap it into my car. how should i go about doing this?
I want to build up my 3.4
Re: I want to build up my 3.4
first, we need goals, and budget, as well as supporting bolt on mods already owned
Originally posted by 97rs4life View Postfirst, we need goals, and budget, as well as supporting bolt on mods already owned
Originally posted by 95firebird3.4 View Postwell i would love to see my car in the 300-350 hp range if that can even happen. i dont really have a budget this would be like a buy a few parts every now and then thing. and i have headers and a CAI
Keep in mind, fur tuning the 3.4, you're going to have to use MegaSquirt or F.A.S.T. Without learning how to use one of those, it's completely pointless to build it up; it could be a very nice build, but without tuning will run like crap!~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by 3.4grapeofwrath View PostI have for sale a turbo kit that came off my 3.4. The car ran a 13.43 in the 1/4. You would still need to fab up some piping and run oil to and from the turbo. The FMU in the kit adds fuel under boost. This set up was on a stock engine.
A FMU is a fuel management unit. It's installed in the fuel return line and under boost it will prevent fuel from returning to the fuel tank. The extra fuel pressure is sent to the injectors. I'm asking $500 for the kit it also comes with bigger fuel injectors. Check it out under search type in v6 turbo kit incomplete.Last edited by 3.4grapeofwrath; 09-17-2008, 01:58 PM.
