might sound silly but i do not want an agressive cam i want something very mild and stock if i have a choice i am goint to be installing my powerdyne soon how would a stock gtp cam and 1.9 rockers turn out? which factory cam will give me the most..
best factory cam?
Re: best factory cam?
i didn't know that.. i do know there is a factory cam a little more agressive than ours i just seem to have forgot where i read the info on it..2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
i would go with a vs cam, it has the same lsa as our stock cam so it doesnt have that loopy idle and im pretty sure it likes FI
with the vs cam and 1.8 rockers you would have ~ .567 total lift which i think is way too much lift for stock heads.
why are you set on having rockers?
Most of the time rockers are an alternative to doing a cam, so if you are doing a cam i dont see the need for rockersLast edited by Meatyshells; 09-17-2008, 12:04 PM.
exactly i didn't want to do a cam not because of time or money thats no an issue i have all the time in the world i just eally like the idea or rockers.. and i wanted the most i could get out of them which is why i wanted a better factory cam.. i will just stick the the 1.9 rockers for my winter install2001 Camaro 3.8 A4
1991 3000GT VR4
oh, ok so you are doing rockers and want to know if a different stock cam would work, gotcha.
answer, both l36 and l37 cams are the same :)
I like my VS cam and it does like FI or nitrous.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
No sound clip, sound clips are useless becasuse they never sound like the real thing.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
my g/f drives this car quite often and we take ot on long rode trips and she hates the lobe of a cam and i don't really care for it in a v6 either..2001 Camaro 3.8 A4
1991 3000GT VR4
Originally posted by Meatyshells View Posti would go with a vs cam, it has the same lsa as our stock cam so it doesnt have that loopy idle and im pretty sure it likes FI
